Post by saratoga on May 15, 2024 19:30:46 GMT -5
Fuel gauge reading 1/4 tank high Pushing down on float gives 1/4 tank Pulling up on float gives well over full. Is it the gauge or sender unit?
bacon
Post by bacon on May 15, 2024 20:33:52 GMT -5
Probably just need to pull the needle off the gauge and reposition it
pili
Post by pili on May 15, 2024 21:35:01 GMT -5
I'd pull the sender out and give the rheostat a good spraying with carb cleaner. Try not to tear the gasket. While you have it out you can plug it in and see if you fixed it.
Post by aeroxbud on May 16, 2024 5:12:59 GMT -5
If you connect the two wires together. The gauge should read full. If it doesn't, it's likely the gauge, or a bad wire. My BWS had a sender unit that was round with a float inside. It was prone to sticking as there were lots of little fingers inside for the float to slide up and down on. Yours might be different.
Post by saratoga on May 17, 2024 15:35:55 GMT -5
Ended up pulling the needle off and repositioning it. Thanks all
