k1v
Scoot Junior
Post by k1v on May 23, 2024 4:40:30 GMT -5
hello, not a huge problem but maybe someone can lead me in the right direction, so basically when im at more than 8 k rpm and i let off the throttle, then again at 7k i try to open up throttle again it kinda bogs down for a sec before going, changed main jet from 92 to 95 cause the plug was a little too light of brown for my liking, now its dark brown, even idle is a little rich i think so, basically ye not a huge problem but a little annoying since its less responsive. carb is 21mm dellorto btw.
bacon
Post by bacon on May 24, 2024 15:41:30 GMT -5
Details about your build would help. Engine, carb, intake, exhaust, etc
k1v
Scoot Junior
Post by k1v on May 25, 2024 14:22:51 GMT -5
Details about your build would help. Engine, carb, intake, exhaust, etc setup- piaggio s6 sport pro, 21mm dellorto, gianelli reverse, carbon reeds, motoforce air filter, dropped the clip one down (the last down position on needle) for more rich mixture, seemed to help now its always dying on me tho when coming to a stop, but i dont think its too lean so ig i need a carb tuning needle kit so i can get a smaller needle... btw the dying happens at about half throthle
