zumanoob
Scoot Junior
Good thing I'm Smrt!
Post by zumanoob on May 23, 2024 16:19:19 GMT -5
Hi guys, there is a cheep E-Ton Beamer for 100$ where I am and I was curious to know if a 2005 Yamaha Zuma head/cylinder would fit on the E-Ton. Thank!
Post by moofus02 on May 24, 2024 9:07:00 GMT -5
The cylinder should fit not sure about the piston. The zuma has a 10mm piston pin the Eton i don't remember if they are 10 or 12mm pin. A $100 Eton is begging for a 70cc sport kit.
Post by Zino on May 24, 2024 14:25:22 GMT -5
The Eton is a 10 mm wrist pin Just like the zuma The aftermarket cylinders do fit I had to dremel off a small bit off a cooling fin for it to sit flush I believe it was the oil pump that I had to remove a tiny bit off the rim for
zumanoob
Scoot Junior
Post by zumanoob on May 25, 2024 0:40:49 GMT -5
The cylinder should fit not sure about the piston. The zuma has a 10mm piston pin the Eton i don't remember if they are 10 or 12mm pin. A $100 Eton is begging for a 70cc sport kit. Haha Right? thats what i thought
zumanoob
Scoot Junior
Post by zumanoob on May 25, 2024 0:41:46 GMT -5
The Eton is a 10 mm wrist pin Just like the zuma The aftermarket cylinders do fit I had to dremel off a small bit off a cooling fin for it to sit flush I believe it was the oil pump that I had to remove a tiny bit off the rim for So i can order a cylinder for a zuma or use my old one and it will fit? dremeling isnt a problem for me
Post by Zino on May 25, 2024 6:49:21 GMT -5
You could use your zuma cylinder The exhaust port on both the zuma and the Eton are restricted
I would just get a 70 cc and let her rip
On the Eton the other restriction besides exhaust port is the crappy exhaust pipe And a restricted cdi the cdi you can make unrestricted by cutting a wire on the back of it
I have done it myself this will let it rev above 8k rpm’s
Post by Zino on May 25, 2024 6:56:21 GMT -5
To dereatrict there is a green wire you cut on the back of the cdi It is referenced in the Eton service manual page 61
Post by Zino on May 25, 2024 7:02:17 GMT -5
Post by moofus02 on May 25, 2024 9:46:43 GMT -5
You could use your zuma cylinder The exhaust port on both the zuma and the Eton are restricted I would just get a 70 cc and let her rip On the Eton the other restriction besides exhaust port is the crappy exhaust pipe And a restricted cdi the cdi you can make unrestricted by cutting a wire on the back of it I have done it myself this will let it rev above 8k rpm’s Mine got the green wire cut on back of cdi. Made night and day difference. I road a Beemer with cast iron 70cc kit, a gear up kit and stock pipe and carb with a rejet. Thing pulled strong, was fast and fun. And this was with a poor tune on the cvt. Clutch wasn't right and the roller weight was too light. Still it was great. Gears really help. I like 10:1 but minds smarter than me claim that 11 or 12:1 is the sweet spot. I tend to believe them but the 10:1 gears in a stock 50 i like better than the 13:1 and deeper. The early zuma 05 and older I think was 14 something to 1 and the gears are the first thing I would do to one of them
Post by 2strokedale on Jun 3, 2024 21:58:57 GMT -5
Thanks for all the helpful information here. I just picked up a 2004 Beamer. After derestricting the CDI box, it will reach 40mph. The 70cc sport kit is probably what I’m looking into for a bit more power and top end.
What do I need to do to help it climb hills better?
Post by Zino on Jun 3, 2024 23:12:10 GMT -5
The 70cc kit will give you more power top end and hill climbing
A variator kit properly balanced would marginally help with hill climbing and possibly give you a couple more mph
Post by 2strokedale on Jun 14, 2024 22:34:41 GMT -5
Thank you Zino. Looking into the 70cc kit for the beamer.
