Post by lauruven on May 29, 2024 10:06:07 GMT -5
I'm a girl and although I have some knowledge of engines & carbs & workings of them & on them my knowledge is limited. So you may have to dumb it down. So a few months ago I purchased a 2021 wolf blaze scooter from someone I kinda know. The guy told me he had made scooter a 100cc, reflecting back I think this guy is more of a scooter hack then a self proclaimed scooter know it all. I met him on a referral thru advanced auto when I was having trouble with my previous scooter. Which he never did fix. So anyway come to find out his claim to it being 100cc on the scooter I recently bought from him was because he purchased a bbk (surely thru amazon) & replaced carb so it's bigger then the stock one it came with, muffler, & spark plug cable. He claimed scooter went 50-60mph easily. Which I found out after purchasing was a lie. It doesn't get above 45 on straightaway. I'd like if I could get it to go at least 5-10mph faster. What can I do? Now also here are some things I've done already and some issues I'm having.
THINGS IVE DONE: replaced cdi, voltage regulator, & spark plug cable. Took carb apart to check bowl & cleaned only 1 of the jets don't ask why I didn't clean other 1 I don't know. I'm nervous messing with carb because last scooter I feel I messed around with carb and it never ran right again. Maybe fluke why it never ran right again or fact that it was a 91 pos yamaha razz with multiple issues but I always attributed it to me messing with carb.
ISSUES: Difficult to start from cold start & will idle lower & lower til stalls unless I keep on throttle. Once warmed up it idles fine for most part and won't stall & will start right up if shut off. Sometimes after riding extended period of time it will idle rough like it will idle slightly higher then back down to normal & when it does this the scoot shakes slightly. Should I replace starter or something else? Also when on throttle going downhill or when fully open on throttle for extended period of time it will backfire a little & on a few occasions it what I would call hiccuped before backfire on straight way while fully open. Which was a bit startling 1st time I encountered it to happen. Backfire isn't loud but I notice it. Guy told me he likes to run his carbs lean could this be causing that or something else? Please any and all advice would be greatly appreciated.
Also why can I never find this brand scooter when looking for parts? What is it called so I can look up parts and stuff for it?
