hoecake
Scoot Junior
Post by hoecake on May 30, 2024 0:37:18 GMT -5
Hello, my Derbi Atlantis is having some problems (as usual). Whenever i full throttle, the scooter seems to bog down. This problem was way worse before i reduced the main jet from a 67 to a 62, but is still there. The scooter also seems to run way better when cold. When cold it seems i can full throttle, and it isn't as slow from standstill. Me not being able to full throttle also creates problems like going up hills. Since i am quite the big guy it dies down and goes about 30km/h up hills, on significantly lower revs than i would like. Everything is stock, but i have removed all restrictions including the brass plate in the carb, the rubber doohickey in the airbox and ive put on a new exhaust. A Yasuni Eco with the restriction still in place. Im confused in what im supposed to do. Thank you guys so much🙏
Post by aeroxbud on May 30, 2024 2:41:15 GMT -5
You need to remove the restriction from the eco pipe. It is seriously limiting your power. The Yasuni eco is not a bad pipe. All its power is low down, so it should climb hills well once sorted. I take it you have got the Piaggio engine with the 17.5 Dellorto?
hoecake
Scoot Junior
Post by hoecake on May 30, 2024 3:47:11 GMT -5
You need to remove the restriction from the eco pipe. It is seriously limiting your power. The Yasuni eco is not a bad pipe. All its power is low down, so it should climb hills well once sorted. I take it you have got the Piaggio engine with the 17.5 Dellorto? yeah, stock 17.5 carb
Post by Zino on May 30, 2024 7:25:12 GMT -5
