Post by kyledude on Jun 12, 2024 9:22:01 GMT -5
I bought the Dellorto 21 ds for my 2008 Yamaha zuma
Wonder exactly what jets I need to tune the carb I tried stock and it get hot fairly quick
What sizes are the jets for this carb and do I need main and pilot jets?
Athenna 70cc big bore kit Dellorto 21 ds Stock air box Malossi "multivar" Variator Minarelli Kit Yasuni R exhaust MICHELIN Bopper tires NCY clutch springs 1500
Thank you for any help
Post by aeroxbud on Jun 12, 2024 9:36:38 GMT -5
Post by aeroxbud on Jun 12, 2024 9:47:48 GMT -5
You might be okay with the stock pilot jet. I would try it and see first before ordering some. You do know the DS has no vacuum feed?
Post by kyledude on Jun 14, 2024 6:28:48 GMT -5
You might be okay with the stock pilot jet. I would try it and see first before ordering some. You do know the DS has no vacuum feed? Thank you. It might be the lack of fuel cuz it starts up but gets hot quick. Maybe I need a different carb that will work with my setup.
Post by aeroxbud on Jun 14, 2024 10:02:50 GMT -5
What ever carb you buy will need setting up. They are a good carb so you should be able to make it work. What temperature is it getting up to? Full throttle or part throttle?
