Post by aeroxbud on Jun 18, 2024 3:52:42 GMT -5
You shouldn't use a torque wrench to undo things. It will mess up the calibration. Before I had a holding tool. I used to use two pieces of metal to hold the flywheel. Then you can undo the nut. You will need a flywheel puller to get the flywheel off.
ice
Post by ice on Jun 18, 2024 5:20:40 GMT -5
yeah i tried to hold it together similary with a wrench but i couldn’t turn it with the torque wrench because im sure a impact wrench was used to tighten it
Post by aeroxbud on Jun 18, 2024 6:35:38 GMT -5
Try a wrench with a big bar attached.
ice
Post by ice on Jun 19, 2024 5:15:35 GMT -5
i managed to get the magnet removed but in the process i broke the stator motor because i tightened the the three bolts too much so im thinking to just sell it because im not spending another dime on this thing, i would rather get a new scooter.
thank you mr aerox for trying to help
Post by aeroxbud on Jun 19, 2024 5:20:18 GMT -5
I can understand that. Sorry we couldn't help you more.
