Bent jets
Jun 15, 2024 10:59:03 GMT -5
via mobile
Post by lauruven on Jun 15, 2024 10:59:03 GMT -5
So i recently removed the jets outta the stock carb on a 2021 wolf blaze to clean them and asses carb after it wouldnt start after driving leaving me stranded. At that time i noticed fuel leaking outta air filter & even after getting it home it continued leaking til tank was empty. The long thinner jet seemed ok but the shorter wider jet after removing it i noticed it was partially bent somehow and some of the side holes where pinched closed because of the slight bend. Also there was some fine grit along seal after taking the rubber gasket off before spraying it with carb cleaner. Now im assuming it is not suppose to be this way and should be straight? I bought the scooter 2nd hand so i dont know what was or wasnt done to it. I know what i was told was done to it but actually wasnt done at all. So is the wider jet the main jet or the other one and should i buy a new carb or just new jets? Side note i havent opened top to check float out yet but thats next when i get home. Just wanted your guys advice.
Post by Zino on Jun 15, 2024 15:44:48 GMT -5
please take some pictures of your carb and the jets
Bent jets
Jun 16, 2024 8:15:41 GMT -5
via mobile
Post by lauruven on Jun 16, 2024 8:15:41 GMT -5
How do i post them here? I already took the pics but im not sure how to upload them on here
Post by aeroxbud on Jun 16, 2024 10:13:13 GMT -5
