Post by mrp on Jun 15, 2024 19:33:14 GMT -5
Hello, i have a Gilera Runner 50, when i accelerate from 0kmh to full throttle it bogs and starts basically choking on fuel, my thoughts is that something might be wrong with ignition cuz i already went from a 84 main jet to a 75 which didn't make much of a change at all, i haven't taken a look at the ignition yet because im unsure what to do there... i bought the scooter slightly built.
Setup: Malossi 70cc cast iron Yasuni Z Dellorto 21mm carb not too sure about the rest but can check if needed.
Post by oliver on Jun 16, 2024 6:43:15 GMT -5
I think you need to jet up, not down. Put a 95 in it and lower the needle clip a groove and see what happens
Post by mrp on Jun 16, 2024 10:38:26 GMT -5
I think you need to jet up, not down. Put a 95 in it and lower the needle clip a groove and see what happens Just tried a 95 jet and it was worse then usual, i put the clip up to the highest groove and put a 75 jet in and it is alot better but stills does a really big bog when hitting 40kmh when it jums to like 11k rpms
Post by aeroxbud on Jun 16, 2024 17:55:22 GMT -5
It could be heavy rollers. I would be going over the bike just to check everything is ok if you haven't built it.
