Post by brokingscooters on Jun 16, 2024 7:28:21 GMT -5
Post by sToRm on Jun 16, 2024 8:50:53 GMT -5
Is that a NOS bottle under the seat?! Also, please don’t mount muffler to the frame. It will crack your header pipe.
Post by aeroxbud on Jun 16, 2024 10:11:45 GMT -5
A turbo Ruck clone is crazy.
Post by brokingscooters on Jun 16, 2024 10:50:35 GMT -5
Is that a NOS bottle under the seat?! Also, please don’t mount muffler to the frame. It will crack your header pipe. Not nos under seat gravity feed for WOT no pusles for pump, These are a few weeks old.. PLease stand by
Post by brokingscooters on Jun 16, 2024 11:06:24 GMT -5
There be the NOS bottles.. I call it NOSty dog. lol I have NO NOS injection yet, only for location. I will have it efi before nos goes on. wideband is on and EGT is next for this guy. Tapped the block for oil pressure and scavenge feed the pump with the wet sump tank. These oil cooler adapters are suction fed, so there is always a negative pressure on the turbo bearings and the cooler and the wet sump tank. The turbo drains into the sump. Carb is blow through boost referenced off the turbo itself. tuning a small enough idle to compensate for the restrictive air system and flow enough right after throttle was not so bad. runs maybee2 pounds so far no real tuning or transmission work on galaxl 80cc bbk .
Post by brokingscooters on Jun 16, 2024 11:07:03 GMT -5
and I will be doing cold bluing on exhaust
