Post by kczukiman on Jan 12, 2012 19:21:22 GMT -5
I was poking around on craigslist as I typically do, and seen this. Its winter, a man needs a project right? I pick it up Saturday at noon. I have a couple extra cylinder kits and coil and a few other odds and ends that may be the trick to getting this thing going. The owner is not mechanically inclined but did say it wasn't locked up. topeka.craigslist.org/mcy/2791715864.htmlI'm sure I will be begging for advise in the next week...
Post by Goosey on Jan 12, 2012 19:28:31 GMT -5
That is the question, did it just not start? or die on the road. Which could be as simple as a drain screw falling out. Luck of the draw
Post by 90GTVert on Jan 12, 2012 19:58:23 GMT -5
Looks pretty clean. Seems like a decent deal to me. Could be something really simple, hopefully.
Post by kczukiman on Jan 12, 2012 20:15:23 GMT -5
The owner says all the plastics are in perfect shape. All parts are intact except a buddy of his STOL the front brake pads off of it and left the caliper hanging which at least he left the screws fastened to it. Go figure? ??
Tweak09
2011 Yamaha Zuma
Post by Tweak09 on Jan 12, 2012 21:18:34 GMT -5
Those are nice scoots. I owned one. Good deal on that. Pretty low miles too. I don't think someone was doing the right maintenance on it if it died that quickly.
Post by lauriejennifer on Jan 13, 2012 0:11:26 GMT -5
Nice deal! I also hope it's an easy fix. I also hope it's not electrical. Ugh, that's my weakness. Electrical is the world's biggest PITA. Here's to hoping it's literally just a screw loose or a dead battery.
Post by stepthrutuner on Jan 13, 2012 0:13:30 GMT -5
E-Tons have a pretty good rep.
If you get it maybe you can get your E-TON to do the HALF-TON (50 mph). ;D
Post by kczukiman on Jan 14, 2012 3:55:51 GMT -5
Nice deal! I also hope it's an easy fix. I also hope it's not electrical. Ugh, that's my weakness. Electrical is the world's biggest PITA. Here's to hoping it's literally just a screw loose or a dead battery. Lol I hope its not electrical. Not my strong point either....
Post by kczukiman on Jan 14, 2012 3:57:39 GMT -5
E-Tons have a pretty good rep. If you get it maybe you can get your E-TON to do the HALF-TON (50 mph). ;D I'm wicha bro!!!
Post by thunderkat59 on Jan 14, 2012 9:35:19 GMT -5
My E-ton has been OK. Im still riding it in 20 degree weather. Cant remember, but I think I posted this here or on the Yahoo Eton site, but when mine mysteriously stopped running, it was just because the the 2 plugs on the CDI unit under the seat had corrision on them. Cleaned it off, instant fire-up ! The kill awitch plug was the offending one. Yellow looks really sharp !!
Post by kczukiman on Jan 14, 2012 11:17:58 GMT -5
This will make Beamer #2 for me. I have a 2004 with only 400 miles on it. Great scoot so far. I have a 70 bbk that got a little scratched up on the cylinder walls when the piston keeper spring came off. I am taking fine sand paper and smoothing the bore. With any luck it should be ok. It only had 100 miles on it when it happened. I just need to find the rings online.
Post by Goosey on Jan 14, 2012 16:24:54 GMT -5
Look for "circlip" I think that's what your talking about. I think it was Brent recently had that happen too.
Post by kczukiman on Jan 19, 2012 22:03:59 GMT -5
Post by 90GTVert on Jan 19, 2012 22:34:26 GMT -5
Both look good. :thumb:
Post by kczukiman on Jan 19, 2012 22:58:50 GMT -5
Both look good. Thanks !
