fhol
![*](//storage.proboards.com/forum/images/stars/star.png)
Peugeot Kisbee 4T 2016
Post by fhol on Jul 1, 2024 17:44:56 GMT -5
I have an old Derbi Senda X-Race 50R '05 with Marzocchi forks. Under the rubber cap on top, there is this white plastic thing that confuses me.
Normally instead of the rubber cap and white plastic thing, there would be a metal cap with a rubber o-ring, and you use a wrench to loosen it. Then you just fill it up with the right amount of oil after you emptied the old oil. This is in fact the case on my other Derbi Senda, a 2017 Xtreme 50SM.
How are you supposed to fill these old ones with the white plastic thing? And how do you remove it? It is stuck in there, and there is no way to get a good grip on it.
Post by snaker on Jul 2, 2024 8:51:54 GMT -5
fhol
Post by fhol on Jul 4, 2024 15:46:52 GMT -5
Unfortunately not the same. Those are the "normal" ones I also talked about. This is what these strange ones look like. There is just a rubber cap, and underneath, is that white plastic thing. You can't use wrench.
![](https://i.postimg.cc/sXvfFqT5/rubber-caps.png)
cabrinha
Post by cabrinha on Jul 9, 2024 16:52:02 GMT -5
Push it in to compress the spring and then remove the safety circlip that keep this plastic plug in place.
fhol
Post by fhol on Aug 7, 2024 13:38:12 GMT -5
Push it in to compress the spring and then remove the safety circlip that keep this plastic plug in place. I kind of forgot about this thread (I don't get e-mail notifications for some reason). Thanks for the tip though! I will try that! Not sure I can remember any circlip there though but I'll try when I get the time. A bit busy with snowmobile repairs at the moment.
