Post by piccolo on Jul 5, 2024 15:06:12 GMT -5
Hi, My scooter is a Yamaha Jog cg50 from -87 or -88. I got a new carb but not quite sure where to connect everything. postimg.cc/yWmtBfVXNumber 1 and 6 is for cooling liquid and I have air cooling so I have covered them with a tube like this: postimg.cc/HVZgDS2v- Number 2 is float ventilation, what do I do with that? These two hoses are coming from fuel tank: postimg.cc/phHNY3WrI have connected the big one to fuel/gasoline connection. - And the smaller one to number 4, which says oil/vacuum connection, is this right? Then finally we have these two hoses coming from what I believe is the oilpump: postimg.cc/0zwHWZHwLarger tube I connected with oiltank. - Where do I connect the smaller one (the one bent 90 degrees at the end)? Best regards, Piccolo
Post by aeroxbud on Jul 6, 2024 17:47:51 GMT -5
The smaller oil line connects to number five. As you have removed the oil from the pump line. You will now need to bleed it or the pump won't work.
