Post by keithhubb651 on Jul 19, 2024 19:14:06 GMT -5
Compression only gets up to 90. I’m gettin a clean blue spark from the plug. I replaced the cylinder head.
(Backstory) Won the scooter in a fantasy football league. It’s always been tough to start n the prior owner only kick starts instead of the electric start. Knowing nothing of scooters I let it sit for a year. I got it to start again but it would immediately stop when I hit the gas so i guess not. I left it alone for 2 more years and now I’m here.
Not sure if this is the correct battery because I have to have it hooked to a jump start just to get a crank.
Idk if I need to replace the Stator and/or Solenoid. *how the heck do yall upload pics on here?
Post by aeroxbud on Jul 20, 2024 3:55:29 GMT -5
How to post a picture. 49ccscoot.proboards.com/post/7984Is it a new battery? Under 12.6 volts is usually no good. I would definitely start by giving the carb a clean. These small scooter jets are easily blocked by old fuel.
Post by mopedmofun on Jul 22, 2024 19:19:46 GMT -5
To clarify, compression is checked with throttle wide open. 90 pounds on throttle closed is likely 120 pounds throttle open and plenty of power
Post by mopedmofun on Jul 22, 2024 19:22:01 GMT -5
Also, a battery, much like a car, can power everything and anything but only have enough juice to start the bike when it is full. Old batteries will run your lights and horn, but may not have enough amps to turn it over.
Post by keithhubb651 on Jul 23, 2024 20:07:07 GMT -5
To clarify, compression is checked with throttle wide open. 90 pounds on throttle closed is likely 120 pounds throttle open and plenty of power Sorry but I need to clarify. The throttle is closed when I’m not tryin to engage the throttle right?
Post by keithhubb651 on Jul 23, 2024 20:11:40 GMT -5
Post by keithhubb651 on Jul 23, 2024 20:12:35 GMT -5
Also, a battery, much like a car, can power everything and anything but only have enough juice to start the bike when it is full. Old batteries will run your lights and horn, but may not have enough amps to turn it over. The battery is only about 2 years old I’d say bought that new.
Post by aeroxbud on Jul 24, 2024 2:43:48 GMT -5
Yes when checking compression you need the throttle wide open.
