Post by hanzek2 on Aug 7, 2024 6:10:17 GMT -5
Hey guys I've got a 96 Yamaha Jog and wanted to do a shut off valve on fuel line but there is 2 fuel lines coming into a carburetor and idk why? Here's a pic of them from a carburetor sketch
Post by hanzek2 on Aug 7, 2024 6:11:51 GMT -5
heres another view of a fuel tap
Post by oliver on Aug 7, 2024 9:20:51 GMT -5
The one on the left side of the drawing is your vacuum pulse supply to the petcock and the right is your fuel inlet.
Post by hanzek2 on Aug 7, 2024 9:23:50 GMT -5
So if I delete this petcock and put a shut of valve it should work right? i just got to block off the vacuum line?
gab
Project is not going to be for long :(
Post by gab on Aug 11, 2024 12:41:40 GMT -5
So if I delete this petcock and put a shut of valve it should work right? i just got to block off the vacuum line? This thing is necessary for your fuel to flow from tank to carb. You should keep that
Post by classacted on Aug 11, 2024 14:57:48 GMT -5
So if I delete this petcock and put a shut of valve it should work right? i just got to block off the vacuum line?run a hose from the tank to the carb and try it. make sure you have fuel flowing RIGHT AT the carb. blocking off vacuum lines should be easy. the worst thing that can happen is it doesn't run.
Post by classacted on Aug 11, 2024 14:59:09 GMT -5
sorry, my quote skills need work
gab
Post by gab on Aug 11, 2024 15:05:06 GMT -5
sorry, my quote skills need work End part you want to quote with /quote in square brackets right after text, put text you want to add outside of between the quote code and the bracketed /quote
Post by classacted on Aug 11, 2024 15:27:46 GMT -5
I hope you don't mind if I try it out on your post, my friend from the north. I don't think preview works, or I don't know how to use it properly. thanks, and here goes.
