Post by diegoro80 on Aug 11, 2024 8:33:04 GMT -5
Hello, First time poster here. So I recently got a delta clutch and had some questions. 1- Should there be some play as shown in the videos. If i tigthen it all the way there is none but im worried it might wear the belt faster.I drove it when there is play for 80 miles and no issues. 2-Delta clutch makes a rattling noise because of the black bracket. Is that normal? 3-Should i use the collar spring with the delta clutch? I did not use it for 80 miles but want to make sure. no problems so far. www.scooterloungeonline.com/buddy50beltpulleydrivenpulley it is number 12 4- got a gates belt that is a bit wider than the stock belt and when given full throttle it feels like bogging. could this be that the belt is not grabbing onto the variator face? Would a couple shims fix this? Would lighter weights fix it? here is the imgur for videos/pictures: imgur.com/a/ObTlGT1
gab
Project is not going to be for long :(
Post by gab on Aug 11, 2024 12:33:45 GMT -5
(Img 1)I would think that the rattling is fine, Clutch has to have some moving parts to function properly
(Img 4)Would rather keep that to avoid unnecessary wear and complications. Effects are negligible but just to be safe you should keep that
I might be wrong on some things, pretty sure some people will find more answers than me. I still think that the spring seat is important
