Post by steele3boyz on Aug 15, 2024 19:54:33 GMT -5
i have 50cc scooter that i have checked all fuses , changed the starter relay and put in battery. the headlight is dim on idle and when at idle i an not charging past 5 or 6 volts ... i rev up and and i goes up to 14.4v is this a sign of stator or rectifier? thanks
Post by FrankenMech on Aug 15, 2024 23:44:54 GMT -5
As we mentioned above check out that manual.
Post by aeroxbud on Aug 16, 2024 5:51:04 GMT -5
It's normal for the headlight to be dim on idle. It's probably an AC system and will only work efficiently at higher RPM. If the idle is very low, you could increase it a bit. Is the starter relay clicking? Have you power in and out of it?
Post by steele3boyz on Aug 16, 2024 6:20:48 GMT -5
no, nothing clicking but if i boost it with a booster pack it starts right up with no issue.
Post by pinkscoot on Aug 17, 2024 9:38:49 GMT -5
These engines have no starter they send the power to the stator to turn and start the engine. I don't fully understand it but your problem is that magical thing it does doesn't work any more. A met or Ruck person should be able to help you.
Post by snaker on Aug 17, 2024 10:21:47 GMT -5
no, nothing clicking but if i boost it with a booster pack it starts right up with no issue. Hold on. You have multiple threads going on and causing confusion You started out saying that it would kick start but no electric. Now it will electric start when jumped? That sounds like symptoms of a dead battery. Trouble shoot for a dead battery
Post by steele3boyz on Aug 17, 2024 17:36:26 GMT -5
ok thanks.. yes i posted in the wrong place at first
Post by steele3boyz on Aug 20, 2024 16:38:40 GMT -5
just an update..... i ran through all tests in repair manual and thank you to everyone. The brand new battery purchased from auto parts store was faulty. New battery and i am in business.
Post by FrankenMech on Aug 21, 2024 3:05:20 GMT -5
Post by steele3boyz on Aug 22, 2024 14:53:00 GMT -5
what a great idea!!!!!
Post by FrankenMech on Aug 22, 2024 15:31:04 GMT -5
DAMN!!! Lost my post due to a computer malfunction. Use SLA batteries with F2 connectors (0.250") Beats the hell out of bolting on wires. No corrosion problems either. Use 0.250" female connectors with a 0.250" male tab on them like: www.amazon.com/REDGOOSE-Semi-Insulated-Connectors-Disconnect-Assortment/dp/B0BRH7DJ7WThey can also be found at auto supply stores for $$$.
Use a high quality crimper, don't try to crimp wire connections with pliers or dykes. OR those cheapo crimpers that come with crimp terminal assortments.
