Post by dirtybird860 on Aug 25, 2024 20:57:10 GMT -5
Recently lost compression after a valve adjustment installing a new bbk. And After opening it up i noticed both of the nuts backed of the valve stem and one stem also fell below the chain tensonior.. Idk wtd. I took of the head and removed the piston to see if I can see it down there.. I cant smh..
Any ideas?
Post by snaker on Sept 1, 2024 21:26:34 GMT -5
Oh, that's some hard cheese. Might be worth the effort to dangle a magnet down the cam chain portage or drain the oil and cross fingers. Beyond that, a motor teardown is in order, unless you want to gamble that the pieces will never get caught in the mechanism.
Two lessons to be learned: 1. Stuff a clean rag into those sort of passages in the future to avoid that. 2. When doing a valve adjustment, always tighten those nuts down hard. Avoid holding back fully tightening because the gap moves. If the gap does move, readjust till right, then tighten the nuts down hard.
Post by dirtybird860 on Sept 6, 2024 2:30:47 GMT -5
Ended up putting the scooter in a indo like straight up and kinda bounced it on front tire and then went in with a magnet. Was able to pull everything out. So lucky. Now I am trying to put a new kit with the naraku 24mm carb for the 85cc and up. Thanks for help.
