Post by athaiguy on Aug 30, 2024 0:57:31 GMT -5
Everything was fine both blinkers were working as they should but now when I put on the left blinker the front blinker does not light or blink but the rear blinker lights but also does not blink it stays on and also the light on the speedometer stays on and doesn't blink. Could this be something as simple as a bulb? I haven't really opened it up to look thinking maybe somebody else is at a similar problem? Also the right blinker front and rear blink as they should and the light on the speedometer blinks as well it's only the left indicators I'm having a problem
Post by snaker on Sept 1, 2024 21:14:02 GMT -5
Those symptoms would normally point to the front left bulb burnt out. That would typically cause the flasher to stop on that side. Broken wires and bad connections could as well.
Post by athaiguy on Sept 2, 2024 23:38:32 GMT -5
Those symptoms would normally point to the front left bulb burnt out. That would typically cause the flasher to stop on that side. Broken wires and bad connections could as well. Thank you very much for taking the time to answer I'll report back I'll take it down and get a bulb replaced within the next week or so we'll see if that's the problem if not I'll have them fix whatever is thanks again
