Post by morphex on Sept 22, 2024 4:10:33 GMT -5
Hi.
I have a Kisbee VGAK1AAAA 2013, where both the front light bulbs for near lighting don't work.
I am assuming this is because of the bulbs, so I was wondering if anyone knows the socket type these have.
Regards,
Morten
Post by aeroxbud on Sept 22, 2024 10:54:37 GMT -5
Most mopeds use the BAY20D 35w bulb. You need to remove it to check. You might need to order it as not a lot of auto stores would stock it.
Post by morphex on Sept 22, 2024 13:22:50 GMT -5
Most mopeds use the BAY20D 35w bulb. You need to remove it to check. You might need to order it as not a lot of auto stores would stock it. Ok, thanks. 👍🙂
