Post by aeroxbud on Oct 8, 2024 3:30:05 GMT -5
Post by skureto on Oct 9, 2024 11:27:56 GMT -5
I live in Bulgaria an thanks for the information
Post by Lucass2T on Oct 10, 2024 1:01:58 GMT -5
to narrow down which yasuni pipe is so we can give you better advice sport pipe( these a lower rpm and stock cvt setting are not far off what you need) Is it all black with no separate silencer so the exhaust flow straight through it Expansion pipe (these are higher rpm and the higher end they are the more you have to adjust the cvt for the tighter power band) These pipes have a separate silencer that sits above the exhaust pipe does the silencer have bolts only to hold it to the rest of pipe hold it on then its a Yasuni Z Is the silencer held on with a spring ?then it is a Yasuni R or a higher end pipe If the silencer is held on with a spring count the zebra stripes on the pipe this will help identify if it is a higher end pipe than the Yasuni r Nice explanation dude! Sometimes I forget how common certain details are to me which totally aren't for others. Great job👍
Post by skureto on Oct 11, 2024 2:45:45 GMT -5
It's an yasuni z
ignelioo
Scoot Junior
yamaha slider 2004
Post by ignelioo on Oct 19, 2024 13:51:44 GMT -5
i wouldnt suggest the mallosi sport, its not that good. if u want power i suggest dr evo cylinder, if you want reliability polini sport cylinder, both dont need new crank. if you are changing crank i suggest streetrace cylinder, but you will need a stronger exhaust and a bigger carburator
