Post by ziptiejones on Oct 6, 2024 12:45:30 GMT -5
Not sure if there's a direct fitment aftermarket sort of thing,but I'd like to get a second wheel, or even be ready to replace this one if something happens with the brake drum. I know they don't have a lot of meat to them so resurfacing can be a pain.
I'm not seeing any new ones listed on sites like partzilla. Is there a comparable axle from something similar like a zuma that can be swapped in and then I can go with whatever spline count wheel that is?
Post by oldgeek on Oct 6, 2024 14:54:26 GMT -5
Not sure if there's a direct fitment aftermarket sort of thing,but I'd like to get a second wheel, or even be ready to replace this one if something happens with the brake drum. I know they don't have a lot of meat to them so resurfacing can be a pain. I'm not seeing any new ones listed on sites like partzilla. Is there a comparable axle from something similar like a zuma that can be swapped in and then I can go with whatever spline count wheel that is? I would not worry about it. Ran the hell out of ours and never had a problem with the brake lining, they are such light scoots. Anyways finding an axel and 10" rear wheel combo with the correct drum size will be a crap shoot. I see vino wheels on feebay on occasion.
Post by ziptiejones on Oct 6, 2024 15:47:37 GMT -5
I had also seen a few on eBay but wasn't sure about that since I was worried about what condition the drum would be in. But I know you're a lot more experienced than I am so I'll take your word on that.
Do you know off hand if the 125 wheel is the same as the 50cc wheel? I feel like I see a lot more 125 stuff than I do 2 stroke stuff.
Post by oldgeek on Oct 6, 2024 20:40:45 GMT -5
...Do you know off hand if the 125 wheel is the same as the 50cc wheel? I feel like I see a lot more 125 stuff than I do 2 stroke stuff. I do not know. However I suspect that the answer is no. Has to be a 10" wheel to fit the 2T Vino, not sure about the size of the 125 wheel.
