Post by detsi50 on Oct 16, 2024 12:43:05 GMT -5
I have already changed rhe spark plug, ignition coil, stator, alternator and cdi and i have checked the grounds, i still have no spark
Post by 90GTVert on Oct 17, 2024 6:28:59 GMT -5
Have you checked ignition and kill switches? It's possible that those have an issue and send a kill signal to the CDI, telling it not to make spark.
It's also a good idea to do continuity tests across the wiring. I had a guy with a 150 that had no spark and I tested/swapped all parts, checked for kill signal at the CDI, and still no spark. It wound up being a $0.10 connecter at the coil that looked OK but was not actually making a connection from the wire to the terminal anymore. Found by doing continuity checks. Check from CDI to coil, CDI to stator and so on just to make sure the wiring and connections are good.
