ignelioo
Scoot Junior
yamaha slider 2004
Post by ignelioo on Nov 3, 2024 6:01:47 GMT -5
hey, i was wondering is it plug and play? like do you just put the sensor on the spark plug and it will work, or will i need to mess with the circuit? also will i need to dremel the cylinder head
Post by bjarkifjarki on Nov 3, 2024 9:30:48 GMT -5
hi as far as im concerned the koso temp guage is powered by its own battery, however if you need to mess with the circuit i think its rather easy, with patience everything is possible. what part of the head do you think needs to be dremeled?
ignelioo
Scoot Junior
yamaha slider 2004
Post by ignelioo on Nov 5, 2024 6:29:07 GMT -5
the part where you put the spark plug in, since the koso ring might not fit in because of the cylinder, if you have a lc cylinder i think thats not a problem
Post by aeroxbud on Nov 5, 2024 8:28:01 GMT -5
It was a long time ago. But I'm sure I routed it without cutting the fin. That was on the vertical Minarelli. I have the duel mini gauge. It needed the extra cable to route it properly. But you can run it off the internal battery, or 12 volts.
