Post by loganszuma on Nov 3, 2024 22:25:39 GMT -5
Hello all, 08 zuma Polini 70cc sport contessa 21 mm polini carb with pod filter 36 and 106 jets ZUMA GP TROPHY CVT kit I think 5g rollers Yasuni exhaust Minarelli contra spring Fresh build, went off recommendations form scooter swap for all the above info. 1st problem reving issues bogs down above half throttle getting into full throttle. Idno if it's the pod filter. I've read that a lot of people have issues tuning that pod filter. Maybe the jets are wrong ? Or needle needs to be adjusted ? 2nd. Issue I am having it's not moving until about half throttle. It does a lot of reving before it moves. There are no instructions for anything I bought so I may have messed up at some point. With the cvt kit I put the 1 of the 2 washers it came with against the case then continued to put on the pulleys. Shown in link below. www.motorparts.it/documenti/pdf_libretti/ISTRUZIONI_9931650.pdf
Post by loganszuma on Nov 4, 2024 1:21:52 GMT -5
