Post by huskyracing on Nov 12, 2024 14:21:57 GMT -5
I recently had a barn find while demolition of a barn structure . It's a 1998 Husqvarna 50cc scooter, From my research it was a limited production run branded under the Husqvarna name( the one I have ) and the parent company Cagiva , based in Italy. It appears it was produced for them by Derbi ( there are some parts that have the name stamped in them) and what I can figure it was based on the Derbi Predator LC. Can anyone verify this info? I need to rebuild the motor ,crank (or rod kit if available) crank bearings , all seals and gaskets , piston and rings and carb rebuild kit. As far as the chassis, it will need a ignition switch (looks like someone wired in a lawn tractor switch). If body panels can still be found, I will eventually replace the damaged ones . Any help would be greatly appreciated.
Post by Lucass2T on Nov 12, 2024 17:21:42 GMT -5
Looks like the Derbi atlantis engine (not the piaggio one) looking at the cvt cover.
Post by aeroxbud on Nov 13, 2024 6:15:27 GMT -5
It was a derbi hunter 50 with different light's and forks. You might have more luck searching for those parts.
