Post by wutang on Nov 17, 2024 20:42:51 GMT -5
Hello everyone, so I have a question. I purchased a used malossi inner rotor system, not knowing there is a small taper and large taper. And as luck has it I ended up with the small and need the large. Do yall think I could drill and tap a bolt in the end of the crank to hold it on?
Post by jackrides on Nov 19, 2024 15:37:41 GMT -5
It will work till it breaks.
