Post by scootpootjim on Jan 27, 2012 19:28:26 GMT -5
I have a Keeway Hurricane 2t with the horizontal Minarelli engine. I would like to know the numbers and letters off the side of the stock and aftermarket crankshaft bearings. I work at a parts warehouse and would like to cross reference the numbers. I can get them better quality and cheaper.
Much appreciated, Scootpootjim
Post by jmkjr72 on Jan 27, 2012 19:46:50 GMT -5
polymer cage SKF 6204 TN9-C4HLHT23 metal cage SKF 6204-C4
Minarelli 20x47x14mm
Post by reveeen on Jan 28, 2012 3:05:00 GMT -5
The "usual" should be: the best bearings you can buy. Economy should NEVER be a factor in crank bearings.
Post by 90GTVert on Jan 28, 2012 10:30:15 GMT -5
They've got you covered already, so I'll just say :welcome: to the forum scootpootjim!
2tfvr
Post by 2tfvr on Jan 28, 2012 10:35:52 GMT -5
i heard that aircraft grade bearings of same spec is also a very good alternative. those who use them are for race applications/drag set-ups but personally haven't used a set yet.
Post by jmkjr72 on Jan 28, 2012 17:53:35 GMT -5
SKF 6204 TN9 C4 crankshaft bearings FAG 6203 bearings (gears) SKF 6200 bearings (gears) FAG 6003 bearings (motor mounts) 2 of each should cover all the bearings in the case i knew i had a list some where just couldnt find it all
Post by scootpootjim on Jan 28, 2012 19:03:29 GMT -5
Thanks everybody!
