Post by jmkjr72 on Feb 5, 2012 0:27:17 GMT -5
if a stock zuma uses a 738x18x30 and a zuma with the stage 6 over range runs a w=17.8 / h=10.6 / l=775; 30°
and the adly case runs a 878 17 28
what belt do i look for if i go to run an over range
Post by 90GTVert on Feb 5, 2012 11:14:19 GMT -5
I dunno exactly what belt, but if you're using the adly cases then you'll be needing longer than even that big 878 length for the larger pulleys. If it's just the vari you're doing, maybe the stock Adly belt? Maybe ask Stage6 or a dealer like SPMoto to be sure.
Post by jmkjr72 on Feb 5, 2012 12:02:48 GMT -5
i sent sp an email but they list a shorter belt in there adly section for running the overrange so they may not even know this is what they list Drive belt Stage6 R/T Oversize Minarelli short w=17.2 / h=8.2 / l=806 30ª
and this is what they have for a stock belt L=786 H=8 W=16,5 A=28°
