Post by fickertravis on Feb 5, 2012 15:57:06 GMT -5
I need nsome 3g roller weights in my variator. But before I go and buy them, is it possible to run three 6g rollers? One in each pair of slots? I know you can mix and match weights but can you take them out too? Thanks
Post by stepthrutuner on Feb 5, 2012 16:32:50 GMT -5
Yeah, you can do that but if you run them for very long like that you can unbalance the wear to your roller paths in the variator. I suppose you could swap them to the other three paths from time to time. Best to use all-the-same weights for smoothest operation.
