Post by racerjohn62 on Feb 6, 2012 20:45:24 GMT -5
looking for help my oil injection is putting out to much oil its coming out the muffler and i"ve tried to adjust it and it didn"t help
Post by 90GTVert on Feb 7, 2012 18:21:49 GMT -5
I'm thinking maybe the check valve is bad and it's leaking oil through even when the scooter is not running. If you pull the airbox off of the carb and look in there, you might be able to tell if oil is just lying around. I assume it smokes really heavily?
Post by racerjohn62 on Feb 8, 2012 0:54:38 GMT -5
no oil in the carb but yes it really smokes alot
Post by racerjohn62 on Feb 8, 2012 0:57:17 GMT -5
do you think i can take the oil injection off and mix the gas
Post by 90GTVert on Feb 8, 2012 2:04:58 GMT -5
