Post by grandman84 on Feb 9, 2012 4:35:03 GMT -5
i have a 2005 adly silver fox with 14000 km on it and it is a 1e40qmb motor 2 stroke oil injected, my problem is i got it drove it about 100 miles then it started missing up now if i start it and go a block or two it start loseing all power and dies out let it sit a min or two it starts back up and does it all again i have cleaned the carb twice now doesnt make any diffrence im lost at what to try next maybe cdi or coil it has a ac cdi on it cause it will run even if batty is dead but i dont think it is charging cause it holds a charge please help i wouldnt think charging would have any thing with it dying out like it does.. if you could help me that would that would be greatful thanks
vvtr
Post by vvtr on Feb 9, 2012 7:09:43 GMT -5
Fuel filter blocked? Fuel tap (petcock) diaphragm bust or vac line perished?
Post by 90GTVert on Feb 9, 2012 11:06:51 GMT -5
:welcome2:
I'm thinking fuel delivery like vvtr first. Sounds like possibly it's having a hard time supplying fuel for anything much over idle. If you're hard on it when it's doing this, then maybe it's too small of a main jet causing a soft seize.
Post by grandman84 on Feb 9, 2012 17:53:29 GMT -5
Well to start off I love this form and thanks for the advice it was a fuel problem the vac switch after fuel filter I guess it is a vac operated fuel cut off was to blame by pasted it and im running faster than before and I have full throttle again but think that I might need to tune the carb but im going to mess with some more later.. Thanks sincery grandman84
Post by felliott on Feb 9, 2012 18:51:39 GMT -5
Try running it with the gas cap loose. the vent in the gas cap may be restricted. If it still does the same thing do what vvtr says.
vvtr
Post by vvtr on Feb 9, 2012 19:13:09 GMT -5
on mine its now got an ordinary on/off tap instead of the vacuum valve. pain in the arse they are.
on eastern scoots, you will probaly notice the rubber tubing is very poor and doesnt last long, including the fuel & vacuum pipe. if its more than a few years old you might want to change it for new, better quality hose.
