beamin
Feb 11, 2012 15:17:53 GMT -5
Post by jakeinva on Feb 11, 2012 15:17:53 GMT -5
:scoot: i will soon be getting a e-ton beamer matrix 2 stroke. it only has 200 miles on it. the guy i am purchasing it from said he cut the rev limiter from the ecu. it also has a racing clutch and a kevlar belt. and he replaced the 8g stock rollers with 6g rollers. i have a vino that is not runnig. but on it i have a exhaust. cluth,bell housing, variator, rollers, hi flow filter. and jet in the stock carb, is any of that compatable with the beamer? and im looking into getting reeds. would they b worth it? also should i rejet the carb? and is the a governor on the carb? ive read the have a plate that restricts the air
beamin
Feb 11, 2012 15:25:22 GMT -5
Post by Deleted on Feb 11, 2012 15:25:22 GMT -5
i will soon be getting a e-ton beamer matrix 2 stroke. it only has 200 miles on it. the guy i am purchasing it from said he cut the rev limiter from the ecu. it also has a racing clutch and a kevlar belt. and he replaced the 8g stock rollers with 6g rollers. i have a vino that is not runnig. but on it i have a exhaust. cluth,bell housing, variator, rollers, hi flow filter. and jet in the stock carb, is any of that compatable with the beamer? and im looking into getting reeds. would they b worth it? also should i rejet the carb? and is the a governor on the carb? ive read the have a plate that restricts the air Those Beamers are notorious for electrical problems.
beamin
Feb 11, 2012 18:17:56 GMT -5
Post by thunderkat59 on Feb 11, 2012 18:17:56 GMT -5
Those Beamers are notorious for electrical problems. Yep. Mine has re-occurring issues. Fortunately its as simple as pulling the tub bucket and cleaning corrosion off the cdi plugs occasionally. Still, a PIA. :banghead:
beamin
Feb 11, 2012 18:54:28 GMT -5
Post by jmkjr72 on Feb 11, 2012 18:54:28 GMT -5
yamaha runs a tk carb so nothing from the carb will work heck im suprised you got an oe yamaha carb to work right with an open filter as youc ant get pilot jets or a needle with the right taper the vino should have a 2 shoe 105 mm cltuch in it i dont know if the eton runs a 105 or a 107 but if you change both it should work
beamin
Feb 11, 2012 19:38:47 GMT -5
Post by 90GTVert on Feb 11, 2012 19:38:47 GMT -5
:welcome2:
Pipe just might work too. Even though they are both minarelli engines they do have some different layouts for pipe designs so it may or may not bolt up just right. The variator should work. I believe both the Beamer and Vino use the small spline crank.
beamin
Feb 11, 2012 19:56:30 GMT -5
Post by jmkjr72 on Feb 11, 2012 19:56:30 GMT -5
yeah i cant remember if we used a guti pipe zuma pipe or vino pipe on the beamer that we piped
beamin
Feb 12, 2012 8:44:46 GMT -5
Post by 2strokd on Feb 12, 2012 8:44:46 GMT -5
:welcome3: So many Minas ! I think maybe some inbreading happened at one point or another with these engines
beamin
Feb 12, 2012 10:39:11 GMT -5
Post by jmkjr72 on Feb 12, 2012 10:39:11 GMT -5
yes and an adly engine is one of those with some inbreeding it is the size of a long case but it has a short case trans set up so you have this massivly long belt
beamin
Feb 12, 2012 21:45:13 GMT -5
Post by jakeinva on Feb 12, 2012 21:45:13 GMT -5
I doubt I will try the variator. More curious bout the reeds and jet. And I was mistakin it isn't the matrix. Its just the regular beamer.do they still have the electrical problems? I also have a "racing" coil/ignition that's was off the vino should it work?
beamin
Feb 12, 2012 22:36:34 GMT -5
Post by jmkjr72 on Feb 12, 2012 22:36:34 GMT -5
i dont think the reeds will work the vino runs an odd reed cage
