Post by keas109 on Feb 15, 2012 17:59:38 GMT -5
:freezing: I need help ok i have an eton 2007 beamer 3 and yesterday it was working fine. I opened the throttle box shaved off a little of the restricter so when i give it throttle all the way it goes a little faster and also i added a new oil injected oil into some of the old oil i had inside. Now it will try to start like the battery is fine but it wont turn over to i took out the carb and cleaned it and it still wont turn over do you guys think this may be a spark plug issue?? please help i need this done in 2 days because its my only transportation to work.
Post by 90GTVert on Feb 15, 2012 18:41:47 GMT -5
:welcome: to the forum.
My first thought is, are you sure whatever you modified was a restrictor? Do you have any, or can you take any, pics of what you did? I thought most of the Etons were restricted via CDI. I've never personally seen a restrictor in the carb of any of the minarelli style 2Ts.
vvtr
Post by vvtr on Feb 15, 2012 19:02:22 GMT -5
please tell me you havent filled the crankcase with oil lol! :/
Post by thunderkat59 on Feb 15, 2012 19:06:14 GMT -5
Two people on this forum have found the CDI unit plugs get corroded and stop working regularly. First, check your kill switch position, then pull the seat tub and spray some contact cleaner or something on the CDI plugs (remove them first), and re-plug.
I need to do this regularly with mine.
Good luck !
Post by stepthrutuner on Feb 15, 2012 20:16:51 GMT -5
You seem to be describing the throttle cable splitter , a strictly mechanical device which has nothing to do with the engine starting if the idle is correctly set for the slide valve. Most likely you knocked a wire off somewhere or your side stand switch (if so equipped) or kill switch is not operating correctly.
Much confusion is created by the varying terminology people use to describe the engine starting processes.
To me cranking or turning over describes the act of causing the crankshaft to turn, either electrically or by foot.
Firing or hitting describes the ignition of the compressed fuel/air mixture at least one time to produce an audible pop or series of pops.
Cranking up describes the engine commencing to run in a continuous mode. Starting is the common term for this.
Does your carburetor not have a nut and threaded sleeve at the top of the carburetor where the cable enters? This is commonly where the operation you performed is done.
Aaron420e
2008 Keeway F-ACT Racing
Post by Aaron420e on Feb 15, 2012 20:45:34 GMT -5
Whats a "throttle box"? We need some pics and more details please. Is it a 1E40QMB engine? The code is on the CVT side near the rear tire. At least mine is.
Post by keas109 on Feb 15, 2012 22:38:20 GMT -5
yes its the 1E40QMB engine and no i didnt fill the crankshaft with oil i took apart the carb and cleaned it out and i havent filled my crankshaft with oil and theres that box right by the throttle that has the starter button and theres a plastic part that hits another which makes it stop at full throttle but if you shave around one millimeter then you get that much more throttle but im thinking its the spark plug
Post by 90GTVert on Feb 16, 2012 1:56:13 GMT -5
You'd need to start by checking for spark if you think it's a plug issue. While the plug is out, see if it's wet or dry or black or clean etc...
