Post by jkpeanut4 on Feb 26, 2012 22:42:30 GMT -5
I have a Yamaha jog and I'm having some problems. Its running like it has a air leak now. On the oil pump I broke off one of the nipples that the oil lines go to so I just used pre mix. Since the pump runs off of the crank can this be causing a case leak now that the lines are off?
Post by jmkjr72 on Feb 26, 2012 22:50:18 GMT -5
no as the gear isnt in the case where did you break the nipple off at on the oil pump or on the carb but also changing up to premix leans the air fuel ratio up too
Post by jkpeanut4 on Feb 26, 2012 22:59:37 GMT -5
It broke off at the pump. I plugged it up at the carb and have messed with the air fuel. Its running really Smokey now when it runs so maybe trans side seal?
