Post by Jwhood on Mar 2, 2012 10:22:00 GMT -5
I have a question can someone help me,my brother gave me a 2007 tgb keywest 50cc scooter and it was in pieces,my question is where does the 2ft rubber snorkle hose hook up to,i have looked everywhere online and have found nothing even in tgb service manual nothing pertaining to where it hooks up to if anybody can help me id appreciate any help,the other piece is hooked to the carb and fasten
Post by 90GTVert on Mar 2, 2012 13:51:09 GMT -5
:welcome2:
Never worked on a Key West, so I'm not sure. Pics of the airbox this hose or snorkel and carb area may be helpful. If you can't do pics, the carb is attached to the airbox via a fairly large tube I assume, 1-2" diameter prob, attached to the carb's inlet/mouth. Then is this a big hose or a more like a vacuum line size or...?
Post by Jwhood on Mar 2, 2012 16:44:20 GMT -5
Here is a pic of airbox,rubber hose hanging is whats in question....
Post by 2strokd on Mar 3, 2012 11:13:29 GMT -5
Usually those hoses go under the floorboard in the belly section of the scoot somewhere... Some also (yours looks like it) bolt to the inside of your body panel, or side panel. The hose is to prevent the scooter from sucking in water and debris very easy. You could put it any place you want TBH but there is probably a place to bolt it on the scoot somewhere.
Edit: I wish i could tell you exactly were it goes :dunno: Im just speaking from other scooters with similar set-ups. For instance, my Kymco Cobra has a hose like that. It goes inside the body side panel. My Aprilia DiTech had one that ran under the floorboard and clamped to the frame. Kinda neat really. That scoot was set-up to be road in the wet for sure. Everything on it was like that and it worked.
Post by jmkjr72 on Mar 3, 2012 11:36:44 GMT -5
on the brotherinlaws old tgb it went forward and clamped on the frame rail at the end of the hose route it where it can get some air and isnt going to suck water
Post by Jwhood on Mar 3, 2012 16:53:16 GMT -5
:stars: :thumb: .........thanks for the help everyone,i just found the bracket it hooks to under seat,it a little "C" hook welded under seat pan on left side of frame just wanted to make sure it didnt hook into anything,oh one more question,when i clean my air filter it say put new oil on filter what kind of oil do i put on the filter and thanks again
Post by jmkjr72 on Mar 3, 2012 17:41:51 GMT -5
i use starting fluid to clean stock type air filters on yamahas you could use dish soap and water but make sure then it is dry dry dry before you do anything else
as for oil i put 2 tablespoons of 2 stroke oil in a ziploc bag and then put the air filter in and work it in the air filter
Post by Jwhood on Mar 4, 2012 2:09:12 GMT -5
Thanks again for the help,great community of ppl here willing to give knowledge to ppl just entering scooter community, ;D
