Post by grandman84 on Mar 6, 2012 19:46:10 GMT -5
i have just taken my 2 stroke motor apart but am unsure if there should be a gasket between the two case halfs or glue or what !!! Im not sure what to do so till i find out i dont think i going to put it back together please help!! im still new oney had it for 2 months and have put a 1000 miles even in the snow lol im crazy but thought i would freshin it up before summer so far i needs front pads but the back were the ones making noise go fiurger thanks ill keep you posted
Post by 90GTVert on Mar 6, 2012 19:59:42 GMT -5
No gasket. Should be a sealant like ThreeBond 1194, Hondabond, Yamabond, Permatex Ultra Grey....
Post by grandman84 on Mar 6, 2012 20:12:03 GMT -5
Thank you maybe there was a leak and this is why some times my scooter doesn't run tip top sometimes maybe it is sucking in air between the to half's so i just want to but it all back together right so i cleaning everything to a shine and checking everything on it but is there anything i should keep a eye out for while i have it a part?
Post by 90GTVert on Mar 6, 2012 20:16:48 GMT -5
Make sure the case sealing surfaces aren't damaged. Seals go bad too, so make sure you replace those even if the ones you removed looked OK.
Post by grandman84 on Mar 6, 2012 20:33:16 GMT -5
yea i want to replace thee crankshaft seals and put new rings in it the jug looks good just hone it a little and so new gaskets and seals new fuel filter and new oil in the rear if the cvt not to sure what kind of oil to use but im not that far yet.. and all i wanted to do was just check the belt and one thing to another its all in peaces all over my house and garage now
Post by 90GTVert on Mar 6, 2012 20:39:43 GMT -5
lol Got just a tad carried away.
The final drive trans uses 100-120mL of gear oil if it's a 1E40QMB / Minarelli.
Post by grandman84 on Mar 6, 2012 21:07:20 GMT -5
yes it is a minarelli 1e40qmb knock off what wight do i use 75w90 95w140 witch weight should i use and thank you for the help it is a adly silver fox 50 it is a 2005 with 14000km in it and will do 40 right now but hopeing to get one or two more mph out of it thinking cdi and new coil and plug would you recomend a cdi with out rev limiter or just stay stock i want more power but dont want to spend to much on it it allready has been derestricted in the cvt clutch and pipes are so much or i would get a pipe and bbk and upjet the carb any ideals please
Post by jmkjr72 on Mar 6, 2012 21:48:40 GMT -5
with the yamaha i run 75/140 full synth gear oil
staying stock i dont see a couple of mph without a kit or a pipe
Post by grandman84 on Mar 6, 2012 21:50:37 GMT -5
if i got a bbk would i have to get a pipe ? i can aford a bbk but not double that for a pipe
Post by jmkjr72 on Mar 6, 2012 22:19:28 GMT -5
no you wouldnt need a pipe just a couple of jets to make sure you get your carb dialed in infact you proably wouldnt even need to do any trans tuneing if you just kitted the scoot you will gain a couple mph plus you will have better acceleration and the fact that the adly gears are 11 to 1 it will depend upon the tire size but you may pick up 5 or more mph with the 50cc bore you just dont have the power to pull the gears that come stock in the adly engines
Post by grandman84 on Mar 6, 2012 22:57:33 GMT -5
you are right it is a 11 to 1 on the gear and im running a 130 90 10 on the back and a 120 90 10 on the front.. the trans have been worked on but not to sure other than someone derestricted the pully washer on the cvt it does 40 mph or so i would like to get more pep from it at stop lights but if all i need is a jet kit and the bbk i was think a 70cc kit i have a 50cc right now and it has a 10mm rist pin with the smaller crank my question is do i need the head or are they the same? as a 70cc or 90cc? thanks for all the help every one just have it apart and want to ride a lot this summer and want to do it right
Post by jmkjr72 on Mar 6, 2012 23:06:38 GMT -5
yeah give you an idea a stock zuma comes with 14.66 to 1 or 13.25 to 1 with the same size rear tire we top out about 40 stock and we aim for 12 to 1 when we kit and pipe them
just look for a zuma 70cc bore you wont have any case work or need a better crank personaly i would go with the top performance trophy bore its a bit more expesnive then some but it has a great power curve and later on if you want to add a pipe it will work with a pipe and it comes with a head most of your better kits come with the new head
to go 90 you would need case work and a crank so you would be spending more then a couple of bucks with those gears a pipe a 70 kit you can see 60 easily
with those gears on my 90cc lc build im aiming for 70 mph yes im putting an adly case in my zuma
Post by grandman84 on Mar 7, 2012 1:18:26 GMT -5
thank you i will think about all that cause my brother inlaw has a 4 stroke gy6 and im faster than him any day of the week but he wants to put a 150 on his 50cc frame and i would still like to piss him off with a small upgrade like a bbk and a jet kit and after market air filter. he is changing everything and i dont want to have to do all that i dont mine mod the case i can do all think i just want a bang for buck as i dont want to spend much on this thing
Post by grandman84 on Mar 7, 2012 1:28:36 GMT -5
this is the scooter i wish the plastic was better but it's not to bad really im just odd or ocd like that thou it has 14000 km in it and will do 40 mph that i have got in video it like to wonder all over the power band map for say its like riding a wave when you get going it scoots some times i cant get to wind up all the way wind temp i really dont think it plays much of a diffrence but i will drive it 25 miles one way and all around after that and come back 25 more miles i havent had to walk but there was once or twice thats all the faster it would go lol haha really the only thing is the battrey wont charge.. Attachments:
Post by MAReames on Mar 7, 2012 2:47:07 GMT -5
I used Permatex Moto Seal on mine. Its the same thing as YamaBond but its only $4
