Post by need4speed on Mar 12, 2012 12:49:38 GMT -5
I can't get my scoot to charge the battery. I can charge the battery and it will hold a charge. I thought it was the rectifier so I bought a new one with no difference. When I hook up the multimeter, it will show 12vdc but when I give it gas no difference. What should I check now, and how do I check it?
vvtr
Post by vvtr on Mar 12, 2012 13:12:09 GMT -5
download the generic chinese scooter manual from carlsalter.com there is a procedure for testing the stator, sounds to me like the stator coils may be duff. also check the earth connections - you say you replaced the rectifyer (rectumfryer lol) but is it a separate regulator? a dodgy reg can dump all the power from the stator straight to ground.
my bet is on the stator though.
Post by Deleted on Mar 12, 2012 17:31:50 GMT -5
white wire from stator (charging circuit) to ground with meter on the ohms scale check to see if its open.
