Post by peteyparado on Mar 25, 2012 5:36:25 GMT -5
working on friends 50mm bbk scoot he got on a mrp variator with 5g sliders we put it on a few months ago an it just went on like a glove everything slid on very smooth.. other day he wanted to change slider weight from 5 to 7grams took off nut starter gear, belt, etc... but the back plate was stuck on what could cause this we finally got it off... i got the same mrp variator on my scoot an the whole assembly slide rite out.. what happen to his?
Post by Enviromoto on Mar 25, 2012 9:54:40 GMT -5
Heat causes them to expand push back up to far on the crank and then when they cool its stuck. Try a torch to heat it up and it should slide off. Also since it is obviously getting hot then you should up the jetting a bit and vent the case.
Post by 90GTVert on Mar 25, 2012 9:55:23 GMT -5
If it's just the ramp plate, as long as it doesn't look damaged, maybe just go over it with some sandpaper in the center till it slides over freely.
Post by Deleted on Mar 25, 2012 12:53:59 GMT -5
or maybe a scotch brite..or emory cloth..snadpaper makes me nervous
Post by peteyparado on Mar 25, 2012 14:24:43 GMT -5
sounds good guys will do
Post by skuldur on Mar 26, 2012 16:46:37 GMT -5
haha funny this just happened to mine, bought that 70 dollar variator from scrappys and about 3 months riding it was really loud, so i took my case off and the same problem for me, the backplate was stuck, although when i finally got it off, it was actually cracked in 3 parts of it, i threw my old variator back on and just like you, i had to use sandpaper to get it back on, as long as you get a pretty high numbered sandpaper it shouldnt damage it at all, i believe i used somethin like 340 or whatever i dont remember i just know it was in the hundreds and it looked like really fine sand, you could also use steel wool if you have that, sandpaper worked for me, although took forever to get it to go back on, try not to take too much off though, i believe there has to be somewhat a little friction between the two, but not much
