jcoahran
89 zuma ii
Post by jcoahran on Mar 29, 2012 15:20:44 GMT -5
can someone post a pic of what the petcock is supposed to look like with all the hoses attached? and could someone relay some syptoms of a bad petcock? this is the 100th thing ive done trying to fix my scoot :swear: :bfg: :beatup: :banghead:
Post by 90GTVert on Mar 29, 2012 15:44:31 GMT -5
Connections : 49ccscoot.proboards.com/index.cgi?board=carb&action=display&thread=3653&page=1If it's bad it can cause you to get no fuel or sometimes can leak fuel into the vacuum line and into the engine. Easy way to check is first disconnect the fuel hose from the carb. If fuel is running out, it's not working. It should be stopping fuel when the engine is off and no vacuum is present. If it's not letting fuel flow, kick/crank the engine over. Then it should squirt some fuel out. If it passes both of those tests, usually it's working fine. You can pull the hose off of the intake though to be sure fuel isn't running out of the vacuum line where it shouldn't be. If it were doing that it shouldn't be starting and the plug should be very wet/fouled.
