Post by teddy554 on Apr 5, 2012 8:36:35 GMT -5
That did make it better but not like it was it is still pretty hard to push and still losing power, it is 50 times better, but not right would, i am going to swap gears from my vento and see if there is any difference. I tired every combination with this gears and different washers nothing help but what 2storkd suggested
Post by 2strokd on Apr 5, 2012 8:46:14 GMT -5
That tells me your tolerances are tight in the trans for sure! You said "its better, but not like it was". What changed? Did you swap gears? Sorry if i missed something. Might need to add a (or a thicker) gasket?
Post by teddy554 on Apr 5, 2012 13:58:20 GMT -5
it just started by itself got done riding and went to push it to put it up and could hardly move it, the only thing i did was put a new clutch in 4-5 days before and change the oil about 30 day before same amount and kind as always
Post by 2strokd on Apr 5, 2012 14:10:58 GMT -5
Man, you dont have a busted clutch shoe do you? Or spring? Im assuming the scooter is complete and all together when pushing it right?
Post by teddy554 on Apr 5, 2012 16:24:34 GMT -5
even with my clutch off and on center stand i can turn the gears with the clutch bell but is just as hard has to push it with clutch on and wheels on the ground. I have tired everything i could think of to see what the problem is, i am going to take gears off vento tomorrow or sunday and install them on cpi to see what happens. i will make video
Post by felliott on Apr 5, 2012 16:51:21 GMT -5
Why don't you try 2 gaskets and see if that helps. I have done this several times with good results.
