Post by chefdan317 on Apr 3, 2012 17:50:46 GMT -5
So I bought my Keyway F-ACT in March 2011, since then I've put almost 10k miles on it. An issue I'm having with it is that it wont stay running when I first start it up, until it warms up from driving it, and the other issue is that when you take off right after starting it, it gets up to about 7500 to 8000 rpm yet is only going about 15mph. Anyone have any input on what the problem might be? I'd also like to go a little faster, I generally max out 40-42mph on flat surphace without any wind. Thanks for your help in advance everyone!!!
Aaron420e
2008 Keeway F-ACT Racing
Post by Aaron420e on Apr 3, 2012 18:10:15 GMT -5
:welcome:
How long has it been since you changed the spark plug? Maybe try a new plug.
Maybe some new weights in the variator too.
jonnienumberfive
just found this 1970 2 cylinder 2 stroke yamaha in a barn,been there since 1980
Post by jonnienumberfive on Apr 5, 2012 16:33:56 GMT -5
check the electric enricher on the carb...adjust the idle mixture screw....of course after this many mles the plug should be new...engine compression should be 155 lb + - 5 lbs....hope this helps get you started
