Post by bradswims11 on Apr 10, 2012 4:30:48 GMT -5
I have just started taking my engine to pieces to install performance gear which will arrive tomorrow. The cam chain tensioner has worn down on the cam chain because the top cam chain guide has worn to pieces. I easily removed the bottom guide but I cant get the top one out, and it seems it is stuck in some kind of grove. It doesnt matter whether I push or pull, twist or bend it it just wont move. Does anyone have any advice on how to remove it?
Cheers Brad
Post by rocketdog on Apr 10, 2012 6:19:35 GMT -5
Brad the tension guide fits into a slot that you can remove when you remove the cylinder. This is the one the tensioner spring presses against. The tensioning plate, the other guide, ain't so easy. You'll have to split the crankcase to replace that.
Post by bradswims11 on Apr 10, 2012 6:27:30 GMT -5
Argh you have to be frickin kidding me. Oh well at least I can change the cam chain too then. Any hints on how to split it without the tool and without hitting the crank with a big hammer?
Post by bradswims11 on Apr 10, 2012 6:29:08 GMT -5
Its also not like that on my one. The tensioning spring presses against the guide which is set into the crankcase
Post by rocketdog on Apr 10, 2012 11:13:23 GMT -5
Its also not like that on my one. The tensioning spring presses against the guide which is set into the crankcase Ooops, your right I got it backwards. You'll still have to split the cases. There's a manual here somewhere. And 90Gt probably has a how to on it as well.
Post by 90GTVert on Apr 10, 2012 12:35:56 GMT -5
I never did any how-tos on splitting the cases on the 4Ts. I've never done a 150 anyway, just 50s. If the 150 is the same, there's no splitter/puller needed, just unbolt it and the cases will come apart.
Post by Fox on Apr 10, 2012 14:53:54 GMT -5
Post by rocketdog on Apr 11, 2012 5:58:37 GMT -5
Fox to the rescue.
Post by bradswims11 on Apr 12, 2012 7:25:01 GMT -5
Got it sorted. IF you remove the cvt cover, then remove the variator there is an allen key bolt, and if you undo that then you can remove the guide rail and install a new one
Post by Fox on Apr 12, 2012 11:38:27 GMT -5
Got it sorted. IF you remove the cvt cover, then remove the variator there is an allen key bolt, and if you undo that then you can remove the guide rail and install a new one Right! I forgot all about that allen plug. :doh:
Post by rocketdog on Apr 12, 2012 18:41:50 GMT -5
Got it sorted. IF you remove the cvt cover, then remove the variator there is an allen key bolt, and if you undo that then you can remove the guide rail and install a new one Right! I forgot all about that allen plug. Me too.
Post by bradswims11 on Apr 13, 2012 5:42:44 GMT -5
Haha thanks anyway guys. I got my 160cc kit on, A10 cam, Performance cylinder head, V8 exhaust and 26mm OKO carb and it runs pretty good! :wheelie:
