Post by jsb010393 on Apr 10, 2012 22:53:29 GMT -5
i just bought a keeway Venus how would i go about getting upgrades like bore kits, exhaust, etc. and how would i go about taking factory restrictors off of it and too make it go faster with out the upgrades for now.
Post by 90GTVert on Apr 10, 2012 23:23:44 GMT -5
:welcome2: The only restriction my Venus had was a washer in the variator. You can try making sure the CVT is in tune before making big purchases. You can check compression and squish clearance ( INFO) and possibly pick up a little performance that way, depending how it's setup stock. Check out the banners on the forum for some parts retailers. Autotech355 on eBay is another good seller. Mine had a 12mm wrist pin and large splines for the variator, but I still suggest checking to be sure you order the right parts if you do upgrades. More info HERE.
