Post by sking3111 on Apr 11, 2012 20:30:52 GMT -5
At full speed scooter feels tlike the belt slipsit kind of like it s on and off grabing.Any suggestions?
Post by 2strokd on Apr 12, 2012 7:36:34 GMT -5
Pull the CVT cover off and take a look. It could be a bad seal contaminating the belt with grease or oil? Could be a bad clutch? Worn belt? Ide take a look... If you need more advice and or help, just ask or better yet, post pic and ask. If you belt is worn narrower than 15mm wide you will loose top end speed. Also look for dry cracks or nasty frays in the belt.
