Post by peteyparado on Apr 16, 2012 4:54:13 GMT -5
recently got a tzr-50 blue racing cdi!! it suppose to have a better spark an better timing curves.i hooked the cdi up an went for a test run,the scoot had a lower idle,bogged,around 1/4 throttle.so i took the spark plug out an tried testing the spark by cranking the motor while holding the spark plug near the scooter frame an watch the spark jump it was real weak hardly could see it. i did the same with my stock cdi an the spark was ten times stronger.so i left the stock cdi in.my scoot runs real good with it..anybody ever used the tzr-50 cdi? an theres a green led light on the cdi were the wires come out do u guys know what the light is for? Is there a good cdi out there that actually works,ncy,naraku,any of the adjustable ones works.. :spark:
Post by Deleted on Apr 16, 2012 6:52:22 GMT -5
TZR-50 is what I run and sell in my performance upgrade...never had a problem.
Post by peteyparado on Apr 17, 2012 0:14:14 GMT -5
i have gotten a bad one!! did u notice the green led light on the cdi? does it come on?
Post by Deleted on Apr 22, 2012 0:19:09 GMT -5
yes mine comes on when i start the engine
Post by skuttadawg on Apr 22, 2012 0:36:48 GMT -5
The engine turning with the starter will never have the plug fire like when the engine is running . A coil may not make much difference but a better wire and plug cap will . A NGK iridium fires the best
