Post by darkdragondsm on Apr 16, 2012 19:10:13 GMT -5
not too happy here. replaced carb, replace spark plug have spark have fuel delivery cranks but does not start. i can see the fuel being purged in the carb when i move the throttle linkage.
i did however noticed the spark a little weak, but u did have spark.
help please.
Post by Deleted on Apr 16, 2012 19:14:25 GMT -5
compression test time
Post by dirtymoosetaint on Apr 16, 2012 19:15:15 GMT -5
do you know what might have happened to make it not start i.e was it running poorly before you replaced the carb?
or is one of those, it was running fine and now doesnt start...
compression?
Post by darkdragondsm on Apr 16, 2012 19:32:28 GMT -5
my compression tester does not have the tiny fitting to test. it was running good when it busted the drive belt. as soon as i replaced it, it wont start anymore. its been sitting for a few months thus why i changed the carb. it was cheaper than a rebuild. i may just remove the drive belt to see if it starts.
Post by Deleted on Apr 16, 2012 19:34:20 GMT -5
ahhhhhh
did you put the rollers back in right? they get all out of whack when the belt breaks and that will make it hard or no start.
Post by jmkjr72 on Apr 16, 2012 19:47:57 GMT -5
did you drain out the old nasty stale fuel if it was sitting for a few months and you didnt treat the fuel its bad
Post by darkdragondsm on Apr 16, 2012 19:51:04 GMT -5
ahhhhhh did you put the rollers back in right? they get all out of whack when the belt breaks and that will make it hard or no start. going to have to check this tomorrow. --------- as for the fuel, yes i did drain it all. replaced the fuel line, added a see through fuel filter, and fresh 93 octane as of last week.
Post by larry001964 on Apr 16, 2012 20:19:19 GMT -5
hummm me thinks valves..
Post by darkdragondsm on Apr 17, 2012 19:28:31 GMT -5
ok peoples. i managed to borrow the adapter needed to do the comp test from work. comp test came back 175psi. this rules out valves, rings, and i believe bearings as well.
anything else i'm missing?
Post by dirtymoosetaint on Apr 17, 2012 19:40:03 GMT -5
are all your wires and lines solid, no cracks or animal chews..lol? if it was sitting for awhile could something have happend to your lines?
Post by Deleted on Apr 17, 2012 19:42:43 GMT -5
if the belt broke while running...and you did not put the rollers back in place when you put the new belt on..that IS a serious problem if not THE problem. it happens EVERY time. that is the very next thing you need to check before anything else.
if nobody believes me take your variator off, put your rollers in all sideways and put it back together and try to start it.
Post by darkdragondsm on Apr 18, 2012 6:15:27 GMT -5
going to do that later on. going to remove the belt for less restriction on cranking and see if it make a diffrence along with your tip.
Post by Deleted on Apr 18, 2012 8:13:45 GMT -5
going to do that later on. going to remove the belt for less restriction on cranking and see if it make a diffrence along with your tip. its not a tip, its a requirement. anytime the belt breaks the rollers have to be put back in correctly. the belt is what holds them in right. when you break a belt here is what you do: clean out all the rubber bits in your entire cvt....put your rollers back in right then put then belt on then crank it up and ride.
Greg
Post by Greg on Apr 18, 2012 19:34:32 GMT -5
I recently bought a cheap no start fixer-upper. Many issues with it, but the biggest issue was a cracked piston. When I went to fire it up with the new top end kit, it would only run on the center stand and the wheel was spinning at idle. Scoot would stall when taking it off the center stand. Since the scoot was stored for a long time, I thought my clutch was frozen. I was really surprised when I took the CVT cover off. The clutch was completely disengaged with the motor off and spinning freely. I took the variator off and at least 3 rollers were in sideways.
Post by darkdragondsm on Apr 20, 2012 12:32:44 GMT -5
just finished messing with the scoot. took the new belt off. i left the rear clutch dead for the time being. i checked the rollers and all other pieces that should be there. i cleaned everything up with break clean, lubed the rollers, and reinstalled it without the belt. put the cover back on and cranked it.
-still a no start.
