Post by racerbugg on Apr 16, 2012 21:16:49 GMT -5
just a thought, i can aquire a kx 60 pipe (FMF) for next to nothing and was thinking of mounting on the keeway. 54mm x 44mmstroke with the autotech 8 ports cylinder kit and mounting it wont be a problem. anybody done this or am i stepping into virgin territory?
Post by reveeen on Apr 17, 2012 2:50:32 GMT -5
All 2 cycle exhausts are a compromise. A scooter pipe trades a bit of top end for some bottom end, otherwise you would not pull away too well from a stop without a manual clutch.... a motocross pipe has virtually no bottom end, because the set-up has a clutch you can modulate to get going, you also have a manual gearbox to keep you in the operating rpm of the pipe.
Not to dissuede you, if you are a small light guy, the chances are pretty good you can make this work for you...... but a large guy, on a heavy scooter, would do better with a "scooter pipe".
Post by aeroxbud on Apr 17, 2012 5:43:29 GMT -5
IF the pipe is cheap enough give it a go. MX pipes have such a narrow power band though and at such high rpm it might be hard to set up for the street.
Post by racerbugg on Apr 17, 2012 8:32:07 GMT -5
i know the FMF pipe puts more mid and top on a kx 60(and most other models of motocross bikes ive ridden) so i might just give it a try
Post by 190mech on Apr 17, 2012 9:16:20 GMT -5
I tried this a few years back,never would get on the pipe..Scoot engines have tiny transfers,reeds,and exhaust ports compared to MX stuff,but we'd love to see if it works for you!! :thumb:
Post by racerbugg on Apr 17, 2012 10:09:47 GMT -5
I did this with an old nh 80 using an 81 cr 80 pipe , intake and carb. But never got around to tuning it. It was dull off the bottom and mid but once it hit 60 kms it pulled super hard ( for a 20 yo scoot ) up to 80 and that was about as far as it went. Then I sold it.
Post by skuttadawg on Apr 17, 2012 22:59:28 GMT -5
I would not think a MX pipe would fit a horizontal engine
Post by racerbugg on Apr 18, 2012 0:52:14 GMT -5
it will with my talented welding and cutting skills.
