Post by mark350 on Apr 20, 2012 21:18:55 GMT -5
well asfar as compression goes ,crap,i hope i dont have a problem ,the scoot is bran new,only has 4 miles if that cuz the speedo is so far off,,so 95 might be the jet i need ,just before you said 82,i dident think that sounded rite,so the higher the jet the richer the mix rite??.Wish i had the rite size compression tester id test it just to make sure i wouldnt dout them being low ritefrom the factory but im hoping its unlikely.The scoot runs awsome besides the bogging at wot,she starts rite up,idels perfect,and the throttle responce up to 3/4 is as good as it gets.
I figure if it still runs lean with the 88 i could always just put the stock air box on.That cdi and coil and plug i bought isint going to make it run any leaner cuz its hotter is it??
Post by skuttadawg on Apr 20, 2012 22:57:15 GMT -5
Post by Deleted on Apr 20, 2012 23:18:02 GMT -5
yes the higher the number the more fuel goes through it. its measured in mm so an 88 is .88mm. a 95 is .95mm and so on. No that ignition wont make it run leaner. Jetting is tricky. i run a 95 main with a uni filter on my 83cc....but this taotao i just did the ring job on wants a 95 too...and that surprises me. It was so lean it wouldnt do more than 5mph with the 85 it would do maybe 15mph with the 90 and runs 45+ with the 95...and a 98 was too much and it went down to about 40mph. I always go up until i make it too rich then go back down to the last one that ran good. rejetting is a PITA but its gotta be done. what jet works best in one might not work in another even if its an identical build. I think my 83cc which has 190+ psi compression needs less fuel to run properly...but the 63cc has a little less...175psi...and maybe thats why it wants more gas i dunno. Lean motors run hot so its better to be a little rich than lean that much i do know
Post by mark350 on Apr 21, 2012 2:03:34 GMT -5
what about the low speed jet,should i order a 35 just to have on hand,or was yours just fine with the 33?
Post by Deleted on Apr 21, 2012 2:15:54 GMT -5
fine with 33
toto50
Bring the Motherf***king Ruckus!
Post by toto50 on May 14, 2012 21:23:33 GMT -5
hows the scooter running? what jet did you end up using? reason im asking im in your shoes now and was wondering?
