toto50
Bring the Motherf***king Ruckus!
Post by toto50 on May 17, 2012 14:48:53 GMT -5
just got my carb today. still waiting for the filter and spark pull. I was wondering should i install the carb now and get it running right or wait for the other parts to do it all at once?
Post by Deleted on May 17, 2012 15:02:06 GMT -5
its best to have the air filter you are going to use when installing and the carb.
Post by 90GTVert on May 18, 2012 11:07:17 GMT -5
If you tune with a stock filter, it will be lean when you add the UNI.
Post by tedwards1222 on May 18, 2012 18:55:43 GMT -5
Whats another type of carb you can use besides Keihin or mikuni?
Post by Deleted on May 18, 2012 18:57:19 GMT -5
toto50
Post by toto50 on May 18, 2012 19:09:51 GMT -5
im in the middle of installing the new carb. the hose at the bottom of the carb what does it connect to or do i leave it alone. also the hose that connected to air filter what do i do with it?Help
Post by Deleted on May 18, 2012 19:20:38 GMT -5
toto50
Post by toto50 on May 18, 2012 19:38:56 GMT -5
well i dont have a catch can..can i just leave it be or what should i do..i dont have much to work with
Post by Deleted on May 18, 2012 19:44:27 GMT -5
what kind of filter is it?
Post by Deleted on May 18, 2012 19:45:31 GMT -5
Post by Deleted on May 18, 2012 19:48:55 GMT -5
you dont have to do it like that though really just get a loooong piece of vacuum line from a parts store and stick a cheap fuel filter on the end.
toto50
Post by toto50 on May 18, 2012 20:26:38 GMT -5
yay baby got it started...now on the adjustment needle to left/right is what?
Post by Deleted on May 18, 2012 20:28:56 GMT -5
the one on the side of the carb? turning it to the right richens it up. usually turning it all the way in then 2.5 complete revolutions out is good. but where do you live again? they set those at sea level and usually they are good out of the box.
toto50
Post by toto50 on May 18, 2012 20:37:53 GMT -5
i live in boston.....just took it down street and it takes off better but i feel it stayed stuck at 40 i usually go past 40. what do you suggest?
Post by Deleted on May 18, 2012 20:39:48 GMT -5
thats hard to answer without being there.
